Goodyear Duratrack installed
#21
Just got the chance to test the tires on Highway .
The Duratrack may be a great tire for offroad , winter and mud but not so good for Highway
Noise level is not so bad , really start to bother me around 70mph and wasnt too bad .
Ride comfort is great on city , going on bumps are much less noticeable
Now the huge drawback is the unstable feeling wile driving the vehicle at highway speeds
the ride comes very unstable , feels like driving a boat , almost scary , may be the sidewall too soft giving a floating feels
I will check the pressure on the tires to be sure it is not part of the issue .
Wondering if anyone got the same problem , an online research show several posts with the same issue but none report for a hummer
Im going back to the shop on Monday , If they cant fox the problem will ask for a replacement .. Yes it is that bad
#22
Im still shocked how a tire company such as Goodyear claims these tires as one of the best , charge over $300 each and the tires are almost on the point to be unsafe .
I will contact them soon to get a replacement or either a partly refund . Im not happy at all paying that amount for a tire which the mainly issue is safety
Pressure is set at 45 psi which is the truck manufacture recommendation . not sure over inflate will solve the issue or be safe .
#23
45 psi if the recommendation for the stock tire. Different tires require different pressures. Granted, my Duratracs were not on an H2, but I don't think you can claim it's a safety issue (yet) when you might just be running too low pressure.
#24
I got to go the shop tomorrow cause also I found the truck is not fully steering to the passenger side , I will ask them the opinion on the psi , will try to either run it 5 psi lower or at 50
No the best week , so far replaced the air filter and ending with 2 MPG less . replace the tires and end with a floating truck which wont turn to the right
#25
What sidewall load range are your tires, D or E?
My 315/75/16 Duratrac's are load range E (stiffer sidewall) and I run 40 psi.
I have no issues with mine but have heard that the load range D's wander a little.
#26
It is " D " I was checking goodyear web and couldnt find the "E" on 17" .... yes most of the problems reported are with the E
i will contact them directly to check if they have it I can get a.replacement
what psi is recommended on your tires
#27
My tires have a max. 65 psi rating. I get a "low tire" warning from the TPM sensors at about 38 psi, so I run them at 40 psi. Any higher, it is too stiff and I feel every little bump in the road.
I like the stiffer E range sidewall because when offroading I air down to about 20 psi and it's perfect for rocky trails or soft sand.
#28
#30
I think it is more the pressure , lot of complains about it. Im running 40 now but at first shop set it at 45 psi .Since change the psi I havent take it to the hwy yet
