DTC Code P0300 - Multiple Random Cyliner Misfire
Old 07-19-2007, 11:00 PM
Calgary's Avatar
Default DTC Code P0300 - Multiple Random Cyliner Misfire
Hey Guys,
Well, my H2 has been in the shop now for almost 2 weeks. I won't go in to the details, but it was running very poorly, and I was getting a DTC code of P0300, "random multiple cylinder misfire". I took it in to the dealer to have them re-flash my ECM back to a stock tune (it had been modified), and the dealer fried the ECM computer. They refused to take responsibility for it, so I told them where they could stick it, and had a tow truck hall my H2 out of their shop. (Needless to say, I am not invited back there again)
I got a new ECM from a place called Wester's Garage (www.ecmprogrammer.com) and installed it. Super shop by the way!! The truck runs again, but still doesn't run properly.
It went in to a local shop that I once worked for many years ago, and whom I feel I can trust. They have been working on diagnosing the problem, but are not having much luck. When attached to the scope, monitoring each cylinder, it appears that different cylinders will randomly shut down, and then start working again.
Has anyone experienced a problem similar to this? Any information might lead to an answer, and will be greatly appreciated.
Calgary.....
Old 07-31-2010, 11:29 PM
Jkmako's Avatar
Default DTC code PO 300
did you ever get to the bottom of the the issue? my Modded truck just started to do the same thing?
Thanks,
Jameson
pm1010
09-20-2019 08:01 AM
juicebox123
11-27-2018 12:38 PM
pakerosny
07-02-2013 12:47 AM
Pdmiller
09-15-2012 10:09 PM
mrigor
07-30-2011 01:39 AM
Quick Reply: DTC Code P0300 - Multiple Random Cyliner Misfire
