2008 Hummer H2 loss of oil pressure after warmed up
Old 03-19-2017, 03:57 PM
ferraribuyer's Avatar
Default 2008 Hummer H2 loss of oil pressure after warmed up
70K miles 6.2L, has 40 psi oil pressure at cold startup. Within 3 miles it slowly drops to about 10 psi. At idle it will go to 5 and then 0. Light says turn off. If i rev it at idle I can get 10 -20 psi when warm. I changed the oil and oil filter after I flushed the motor. Oil was clean. I hear nothing wrong, no noises in the engine. No rattles or any valve or piston slap noises.
The oil sender is good I would assume since it shows up and down values of oil pressure. I think I have an internal oil leak like a oil pump pressure relief valve or spun bearings? How can I test which one it is without taking the motor apart? A mechanical cause also reads the same and will read 0 psi.
I won't know until I replace the oil pump if its a stuck relief valve. Need some advice.
Old 03-19-2017, 11:00 PM
flyday58's Avatar
Old 03-20-2017, 03:28 PM
probably a main bearing with no noise? Maybe you can do the main bearings with engine still in the truck?
Old 03-20-2017, 07:42 PM
flyday58's Avatar
Still there Enzo? Had my oil pressure sensor changed today. There wasn't a screen installed but they put one in for me. Get it back tomorrow, we'll see how the pressure acts.
Old 03-20-2017, 08:05 PM
that won't help its only for AFM hummer doesnt have that. oil pump pressure relief valve if we are lucky. Did they try do a mechanical oil pressure gauge?
Old 03-22-2017, 05:46 PM
still didn't work?
Old 03-23-2017, 05:05 PM
flyday58's Avatar
Mine is fixed.
Old 03-23-2017, 05:10 PM
no way by putting the filter in under the oil pressure sensor?
Old 03-23-2017, 05:11 PM
You do it for both hummers you have?
tell me more and what to do!!!
Quick Reply: 2008 Hummer H2 loss of oil pressure after warmed up
