2003 H2 Limo problem
Brake ABS and TC lights stay on and chime stays on. This happened after I changed the battery and also found a short on the main alternator wire. I tries disconnecting the battery and resetting the computer but no change. I also tried pulling fuses for abs but no change. I am stuck.
This was MOVED from the Hummer Forums Help and Suggestion Center because, like the first post stuck at the top of that section; https://www.hummerforums.com/forum/h...section-30002/
says: This section of the forums is NOT for vehicle questions. It is where you can ask questions about HOW TO USE FORUM FEATURES ONLY!
We don't have a limo section, so this is as close as you are going to get.
alrock
11-21-2012 01:06 PM
pteam
18
04-25-2008 04:36 PM
indyh2
24
01-26-2008 10:24 PM
