Rear Door won't open
Old 06-05-2011, 06:34 PM
maxjoann0120's Avatar
Default Rear Door won't open
I have a 2006 H2 and my rear door doesn't open. Could it be a fuse?
Old 06-06-2011, 05:32 PM
drtom's Avatar
Banned
dont know h2,,,but h3 has 1 fuse for all doors,,complex controls.
im trying to figger a way to beat the back door,not done yet.
i want a pull cord
Old 06-07-2011, 01:24 PM
Pauldy's Avatar
You should probably try qualifying what you mean by "doesn't open". it could be all kinds of things a fuse, relay or even something mechanical in the door.
Old 06-09-2011, 01:04 AM
drtom's Avatar
Banned
Default wont open=wont open
wont open means,,,wont open. u know,it opened last friday and today,under same conditions,,,,it wont open.
so now the question is, why? it can be a lot of things.
what concerns me is the total dependency on the motor in the door. if it dies,THERE IS NO WAY TO OPEN THE DOOR!!! there is nothing moving in my h3 door that i can touch from inside with the cover off. and im trying under ideal conditions,door open!
its all enclosed in a plastic enclosure,a rod goes up to the handle. it goes up/down the same when locked/unlocked. something in the box lets the rod open the door when unlocked.
im looking at worst case, no motor action situation because,,,THATS WHERE WE WILL BE,SOMEDAY!! today we are real lucky if its ,wire,fuse,switch,connector,contact,,,,,
any genius out there?? the other h3 doors have a flip tab to unlock,not the back, a real problem huh?
Old 06-16-2011, 05:15 PM
drtom's Avatar
Banned
on the h3 the wires from the unlock motor go to the driver door control buttons u need to find those wires,see if they are ok. same relay controls back doors and tailgate but could be contacts/connections
slider28
09-27-2014 05:11 AM
johnmully
09-14-2013 11:51 AM
FurbiesAndBeans
06-09-2010 10:58 AM
IceIsFun
02-14-2010 03:32 PM
Hurst
11-01-2009 05:14 AM
Quick Reply: Rear Door won't open
