16x8 backspacing?
16x8 backspacing?
Hello All,
Will a set of 16x8 wheels with a 0 offset and 4.5" backspacing stick out a lot? I'm looking for a new set of wheels but a little clueless as to what an H3 can accommodate. I have a set of E&G fender flares and would like the wheels to match the fenders but not stick out past them. Thanks in advance!
Max
Max
RE: 16x8 backspacing?
In my opinion 0 offset is perfect, but I like the wheels to stick out a little bit. 0 offset should put you about one treadwidth out from the fender. I have not seen the fender flares in person to know how wide they are. From pictures it looks like they are about as wide as the distance the tire would stick out. The width of the tire also place a role in this too.
The only way to know is put them on and see how it fits. Most Offroad shops will let you do this without having to agree to buy them. Post some pics if you get them on.
I actually have a -12 offset (which pushes the rim out further than a 0.) You can look at my photos in the gallery - search smokinhummer.
One thing to consider my tires are also 13" inches wide. Not your standard 33x12.50 which are usually 12 inches wide.
Plug in the stock specs, listed below into this website and it will give you an idea of what you can use.
http://www.wheelsmaster.com/rt_specs...oliath%20Kumho
If you can look on your stock rim it will be marked/stamped with the offset/backspace
OEM tires: 265/75-16 (802x265mm). Big Hub. 32 x 10.5 x 16
Bolt OEM tires: 265/75-16 (802x265mm).
Bolt pattern: 6x139.7 (6x5.5).
Offset: 15 to 35 mm.
Tires up to 842x305mm.
Rims up to 26x10.0".
