Scoshe gm2000a or metra gmrc1?
Old 07-24-2017, 08:00 PM
Mounted88's Avatar
Default Scoshe gm2000a or metra gmrc1?
Hello,
This is my first post in here. But I have a question about aftermarket HU. What is the best chime unit to install.
Today i I installed a scoshe gm2000a and lost the R.A.C feature, so the radio will stay on for about 1 minute after the ignition is off and the door is open. The chime unit I took out sounded like was about to die when it chimed. It was a peripheral gmco.
Would the rac feature be retained by using the metra instead of the scoshe? Any other suggestions are welcome.
I have no on-star or Bose system.
2008 h3, standard system.
thanks everyone
chris
Old 08-02-2017, 01:33 PM
Welcome to HF.
I do not know what a chime is for or what you would do with it. I did google scoshe gm2000a and noticed that the H3 is not on the list of compatible vehicles?
Better to post this in the H3 section, so I MOVED it for you. Not much going on where you posted it, maybe you will get some input now.
Good luck.
Old 08-02-2017, 02:08 PM
Mounted88's Avatar
Welcome to HF.
Good luck.
Thanks for the reply Doc
The chime unit maintains all the warning signs in the vehicle after you replace the factory radio with a aftermarket head unit. I know it doesn't list hummer in the compatible list, but it is compatible. Says it on the front of the actually package, but not on the list. I know weird. Also thanks for moving to a more active section.
Old 08-03-2017, 07:28 AM
Just visited the Scosche website and entered HUMMER H3 2008 and it spit out this harness GMSRCL2. You bought the wrong harness form Scosche.
4u33er
05-20-2013 08:16 PM
alex2mil
07-18-2011 11:19 AM
scottminor
02-27-2011 10:05 PM
tarheel_34
01-31-2008 08:23 PM
BirchH3
05-31-2007 01:32 PM
Quick Reply: Scoshe gm2000a or metra gmrc1?
