h3 Aftermarket Stereo - Can't Find where to connect ACC wire?
When I was installing my aftermarket, turns out that there is no ACC wire for the Factory Head Unit, and all of the research I did showed many (hard) alternatives like finding the ignition wire under the steering wheel or going into engine bay - fuse box :confused:
USE THE YELLOW WIRE ON THE REAR WIPER CONTROLLER!!! :eek: check out this video (not mine): seems like a lot of people went to too much trouble for a simple function, that had a simple solution. I hope this helps! -- hummer on! SG |
this is donjon mine too...not by me... however, if that wiper comes on, it kills the radio...I don't suggest this... they make kits to plug into the stock module...
Originally Posted by Mike_Utah
(Post 347755)
