Front door speakers not working
I have a 2006 h3 Hummer with the moonso sound system and I am currently replacing all the factory speakers but the front door speakers aren’t working. The back door and tweeters work and I even put in new speakers and they don’t play any music. This is also the case when the factory speakers are in. They won’t play any music. Anybody with any comments or suggestions on why it’s doing this? |
Stupid Question. Are the fade settings set to the middle position?
If the fade in fact, is in the right position, I was having a similar issue in one of our 2006 and it ended up being a loose connection in the large connector between the door and body that has a handle to push down when it is seated properly to lock it in. I could wiggle the connector and get the speakers to work.
Originally Posted by TAINTER
(Post 352285)
Originally Posted by atvspeed4
(Post 352295)
(Post 352295)
Originally Posted by akbaradeli
(Post 384805)
When all of the speakers in a car audio system all stop working at once, the problem is usually in the head unit, in the amp, or in the wiring. In some cases, an issue with the wiring between the head unit and a single speaker can even cause all of the speakers in an entire car audio system to cut out at once.
