What are these wires/plug for ? thanks
Old 08-16-2015, 03:00 PM
Retired Baby Boomer's Avatar
Default What are these wires/plug for ? thanks
hmmmmm
Old 08-16-2015, 03:51 PM
Baldfox's Avatar
I think that's where a previous owner had roof lights. I have the same type of cable on mine. You can add a light bar or something to it.
Old 08-16-2015, 10:30 PM
MH3's Avatar
MH3
MH3 is offline
Yeah...at one time, your vehicle had a light bar attached. The other end of your wires should lead to a switch on your dash somewhere that controlled the lights. My H2 has the same wire bundle up top. The switch on the dash doesn't look aftermarket, so I'm assuming the light bar was installed as an original option. Too bad I can't find a replacement...
Old 08-17-2015, 10:39 AM
fyr145's Avatar
Default Light bar
Yes, they are correct. I have the factory light bar option on my H2. The pic you posted is the factory connection for the either the high or low profile light bar that was on the roof.
That circuit connects to a couple of relays under the dash that control the load for the power to the lights. On the other side of the relays was the switch and power wires that was mounted up by the interior map lights. I didn't want mine up there so I drilled a small hole just under the headlight switch for a more convenient location.
Old 08-17-2015, 06:36 PM
MH3's Avatar
MH3
MH3 is offline
Here's what the switch looks like in ,my H2. When I activate it, the amber light still glows so I know it's still gettin' juice...
Attached Thumbnails What are these wires/plug for ?  thanks-fog-switch-1.jpg
bheff
07-12-2011 09:52 AM
luda81
12-22-2010 05:02 PM
Ghostrider
08-27-2010 12:59 PM
nate_b
03-07-2007 11:31 PM
jm4490
12-30-2006 05:38 PM
Quick Reply: What are these wires/plug for ? thanks
