2007 H3 audio Quest
Old 04-10-2011, 01:39 AM
taz6887's Avatar
Default 2007 H3 audio Quest
I am trying to have an after-market head unit installed in the 2007 H3. I have a Monsoon speaker system - whilst I know its a bit rubbish, this will also be replaced.. Subject to pocket allowing.. :-) oh and Wife.....
I have had a new head unit installed but I get a horid whining noise... when you accellorate, which is driving me mad. I was told that this was a dirty earth, but having run the earth wire directly from the new head unit to the battery this did not cure the problem... Any ideas>?
Old 04-10-2011, 08:03 AM
drtom's Avatar
Banned
1. monsoon is fantastic,really great.
2. whoever wired your stuff screwed it up.
have them restore the original wiring,it
worked fine. i hear zero noise,,on my monsoon.
Old 04-11-2011, 04:55 AM
taz6887's Avatar
Drtm,
Thanks for your input, when you changed your head unit -
1) Did you retain the Monsoon speakers then? I am guessing so.... :-)
2) Did you use a PAC wiring harness? if so which one???? perhaps this is my error.... :-(
Old 04-11-2011, 09:25 AM
drtom's Avatar
Banned
sorry,mine is stock monsoon,i love.
there are 1000 posts about adding ext audio.
u can search
Old 04-11-2011, 10:11 AM
Spelled's Avatar
What you are describing sounds like alternator whine. Are you using an external amp to power everything, or are you using the factory wiring? I assume that you are using an external amp, as you mentioned running the earth (ground) to the battery itself. You can google altenator whine and find many causes of this. Keep your ground run as short as possible as this is the main cause of the whine, any bare metal is fine. Make sure that you have well insulated wires, and that the speaker wires aren't run near that +/- power cable to the amp either. Quality RCA and speaker cables are a must also. House speaker cable has also caused this issue for me. Other than that, you must isolate the loop (something I haven't had to do). Make sure that you use the proper size wires for +/- and that you fuse them properly!!! Good luck!
Old 04-11-2011, 10:49 AM
HummerWorks's Avatar
You may have a ground loop issue. A ground loop isolator or some diodes or capacitors may help you out. Do some googling on the subject and you find all the info you need. Was an issue with mine and solved my problem.
Old 04-14-2011, 01:40 PM
Hummphrey's Avatar
What kind of radio did you install?
Old 04-15-2011, 02:00 PM
drtom's Avatar
Banned
just a couple notes.
speaker wires have nothing whatever to do with alt whine.
since the stock radios have no whine, using their unmodified power wiring seems to be a good idea.
ditto for any mods to ground. the mfgr did a good job.
finally,lamp cord is fine for short runs,10 to 20 feet,like #16 or 18,up to 200 to 300 watts. no monster cables needed.
if u have noise/whine,someone messed with the good orig wires
Old 04-16-2011, 02:34 AM
taz6887's Avatar
The wiring loom of the car has not been adjusted... to the best of my knowledge... although I will have to double check....
I have a PAC C2R-GM24 wiring harness on order and hope that this solves the issue, as I am concerned that the whining noise could be from a poor wiring harness connection...
jmada
02-28-2012 04:36 PM
Pauldy
12-31-2011 04:53 PM
H3 Marine
10-20-2009 11:17 AM
Marauder
06-30-2008 02:52 AM
2007H3
05-26-2008 11:15 AM
Quick Reply: 2007 H3 audio Quest
