Wiring Question on roof lights
I got my hummer h2 with the XTCbar lights. 110 watts total on 4 lights , i dont have the wiring harness and they want 250.00 dollars for it which i find very expensive , so i'am going to make my harness. The lights have 2 wires one black and one white is the black ground and the white power . Anybody that can answer me please let me know . RKI
RE: Wiring Question on roof lights
DC doesn't really matter.... but black is usually always ground in a DC circuit.
I agree with muddydawg75, black should be ground in the GM wiring. However, blackis always hot in other applications. I would consult Chiltons or the dealership to be sure because the color codes are variable in cars. White would be neutral in other applications.
thank you i let you know what happen. RKI
You should be fine.... the lights are not gonna matter... Just run a ground to the black throughout.... run a red wire to the line side of the switch and a red from the load side and to the white wire and you will be fine... if you want to get creative use two switches and run outsides and insides...
| All times are GMT -5. The time now is 04:42 AM. |
