Wiper not working properly
Every time I start my Truck the wipers turn on and then just stop where ever they feel like. To bring them back to the park position I have to use the highest speed cause that the only speed that works. Does anybody know if its the wiper motor or the wiper switch?
Thanks |
Mine was doing the same, Dealer replaced wiper motor.Happened to have one in stock!
Originally Posted by hectour
(Post 256282)
Thanks |
Thanks guys I know Im way out of warr. so im gonna have to do it my self. was the motor expensive?
this topic was covered b4,?? back then i mentioned,1 i never saw the h3 motor, 2 i had a similar problem with a pontiac trans sport minivan wiper.
the problem was solder on the circuit board inside the motor case. it does the delay the connector pins needed to be resoldered. could be?? same. caution,,remove the batt terminal b4 moving the motor. if it decides to rotate it has power to cripple your hand and you cant stop it. very dangerous |
| All times are GMT -5. The time now is 10:18 AM. |
