Window Defroster Rattle/Vibration
I have a rattle/vibration coming from the top/center section of the dash area, when the defroster is turned on. The noise/rattle is only audible when the defroster is on, and only at around 1000-1100 rpm's. The issue appears to be within the blower motor or vent control mechanism. Anyone else have this issue? I'm sure it is an easy fix, but will likely require the removal of the dash, which could open up a host of new noises and rattles. [:@]
RE: Window Defroster Rattle/Vibration
No one else has this problem?? Good, maybe a found an issue that is unique to mine and not an H3 design/build issue(Encoder Motor, Cracked roof moulding, etc). ;)
