Doc Olds |
04-16-2014 08:59 AM |
Ah..... ehem, ........... the H3 was DESIGNED to allow for 35" off road tires without modification. It was not a mistake or coincidence. ;)
Will 35s dim street performance? Yes, but 1000s of them are out there driving every day on 35s.
Ask yourself one question first. Most 35s are not 35" in diameter, they are mostly 34.4-34.5". 285s and 305s are almost all a true 33" diameter. Do you think you will be off road enough that an extra 7/16" of ground clearance is worth the change in final drive ratio cause by the larger tire? Personal preference is what it boils down to. I'll stick with 33s with my I5, if I had an Alpha, I would run 35s.
