Where the heck can I buy a fuel bucket????
I really need a fuel bucket and I can't seem to find one anywhere. This is the piece that fits over the fuel neck. Thanks.
wow, I just did a google search and hundreds popped up.
What search term are you entering? When I search 2006 H3 fuel bucket, H3 fuel bucket, or Hummer fuel bucket the results are either for the trim, fuel door or instructions etc.
Try
HOUSING. Fuel Tank Filler. Around $40.00 FLARE/REAR WHEEL OPENING-LH. Fits: H3 | Tonkin Online Parts Stock Code 15794626 Manufacturer GM Categories Body > Other; Body > Rear Compartment and Roof; Exhaust System > Other; Fuel System and Emissions > Other Assemblies FLARE/REAR WHEEL OPENING-LH; FUEL TANK FILLER PIPES & HOSES |
FUEL POCKET for a 2006 Hummer H3 (15104508) Part Discontinued. don't know if the newer fuel pocket Stock Code 15794626 (2007 to 2010) will fit.
Thanks Krome, I'll check into it.
I'm sorry mismatch. I don't know what I was reading but I thought you wanted the fuel doors. There's tons of those. You will probably have to contact G.M. to get that.
What is wrong with yours? |
on Ebay for $35.22 Hummer GM 15794626 Exterior Fuel Pocket | eBay
It's called a fuel pocket. Yes there is lots of them for sale if you google it.
Unfortunately most of the search results provided are for 2007 and up. I'm not sure if it will fit as Krome mentioned, there are two different part numbers. I'll keep looking around, I'm sure it will be a bit easier with the part number and correct name of the part! Thanks.
