wheels
Hello all,
I am new to the forum, but not new to Hummer. I know this is a repetitious question, but I've been reading and searching for 2 days and have come up with a product. I am leveling my H3. Im upgrading from 285/75r16 to 295/75r16. I know I can go larger but i like this feel best. Here is my question, Hummers are very tricky to find wheels for, so please if you can I am just looking for a yes or no. American Racing AR172 16x8 6x139.7mm, 0mm offset, 4.5" backspacing bore size 108mm, and i will be using 108mm-100mm hub centric rings Can a professional on here please give me an approval before I order, Id greatly appreciate it, THANKS |
If somebody else looking into wheels is curious, this set up worked.
I went with a Ready Lift leveling kit I bought the wheels mentioned above (0mm offset, 4.5" backspace) but did not use the hub centric rings as the center caps did not fit through them. No vibrations as of now. Tires are 295/75/16 but definitely could have gone bigger, or at least m/t. http://www.dropbox.com/s/0zcp8q73lhy...%20PM.jpg?dl=0 |
You should have saved your $$ for the Ready Lift kit, the stock TB keys will do the same thing and are already installed from the factory.
Yup, "leveling kits" are a waste of money, not needed on an H3.
Asantoro... That's a shame nobody got back to you sooner, especially since it had over 300 views..! I think it looks great though, much better than factory. All in all, I think it's a win.
