wheels
Any one know if any other vehlcle wheels will fit h3x .I have a new set of goodyear 37 1250 x16.5 tires and a new set of 265 60 x17 tires thanks
May be this can help...or not.
Chris Wheel Bolt Pattern Cross Reference Database and Conversion Guide: HUMMER H3, H3X, H3 ALPHA, BASE, LUXURY |
Neither one of those tire sizes would be good on an H3.
37 1250 x16.5 will be too big without a body lift and major inner wheel well trimming. They are very heavy and the I5 motor will struggle. 265/70/17 are too small, only about 29-1/2" diameter. They would look ridiculous. Standard H3 tires are 32" or 33" diameter. You can go up to 35" diameter without modification as long as your wheels have the correct backspace. |
once again are there any 16.5 or 17 inch wheels that will fit h3, hell i had 42s on my under powered 93 2 dr h1.I know what i am doing ,i have owned 41 h1s mpp8s as well as 1 h3
Thanks Happy Hummer
I built , drove and owned the m998 that was in the movies Major Payne, Species 2, Godzilla (1998), war of the worlds, Etc
Well since you know what you are doing, you don't need my help.
Originally Posted by ollied
(Post 316858)
Thanks RSC
The reason i want to use Goodyear 37s is i have 3 new sets , (12) left from i had my h1s so i would like to use these on my h3. The 37s are only 35 inchs tall. All i need is wheels. plain steel whells would be ok. may have to change centers as most 16.5 wheels are 8 lug.Back in the 80s i had 16.5 wheels on a 80 ford bronco. may have to use mil dodge 880 wheels. as far as power my i5 3.7 is not stock. I tow a 16 ft trailer hauling a 52 m37 army teuck 7000 lbs with no problem as well as a dump trailer hauling 3 ton both trailers have brakes
