Wheel bearings! Can they be adjusted???
Ive noticed i have slight movement in the front wheel bearings on my 03 H2. Are the wheel bearings roller bearings??. Or non adjustable tapered bearings??.
Thanks for any help given. |
The front hubs/bearings on the h2 are a sealed unit that is not serviceable. You need to replace the entire hub. H2's eat hubs regularly.
Originally Posted by HumminNBoatin
(Post 221035)
I just did mine on the right front. Same as a chevy suburban 3/4 ton
Good luck!...Pretty easy to change...I just change mine last month... As long as you have the right tools ..ie breaker bar (long) and power tools you're good to go.
The front wheel bearings are the same as those fitted on the Silverado, not sure if that helps any in the UK. Theres always eBay I suppose
