Whats up with those broken exhaust bolts
Old Jan 21, 2016 | 10:02 AM
H2Miami's Avatar
Default Whats up with those broken exhaust bolts
Sorry if this may be a stupid question but whats the big deal with the broken exhaust bolts ...
I understand that it may came loose if all get bad but 1 or 2 , what may affect
I just found there is a broken on each side of mine .. been like that for a long time and everything seems to be normal and under control
Old Jan 21, 2016 | 10:47 AM
mcioci's Avatar
I had a broken one on my truck and I replaced it since it started making noise like a bad lifter until the truck warmed up. I just didn't like to hear that noise, other than that I don't think it will affect your truck at all unless more bolts break.
Old Jan 21, 2016 | 07:31 PM
H2Miami's Avatar
I agree about the noise . but I dont want to get involved in the fix whixh seems to be hard just for a noise . Thats what Im trying to find out if the problem stop on the noise or may damage or cause malfunction.
Thx
Old Jan 22, 2016 | 06:15 AM
mulepic's Avatar
My 08 makes that noise and I have always thought it IS a bad lifter. Once the truck is warmed up the noise goes away. Where are these broken bolts located and are there any pictures or write up on how to fix? Again, mine is the 6.2, does it have the same problem?
Old Jan 22, 2016 | 07:28 AM
mcioci's Avatar
Thx
A broken bolt won't damage the truck but those hot exhaust gases may eventually find its way into your truck. The fix is labor intensive. Really depends on where on he bolt did it break. If part of bolt is sticking out a little then you can grab it with pliers and just unscrew it out but if none of he bolt is sticking out then you have to drill a hole into bolt and use special tools to extract it. Check out this site for answers: https://www.yourmechanic.com/service...ld-replacement
Old Jan 22, 2016 | 07:30 AM
mcioci's Avatar
If noise goes away then it's a broken exhaust bolt. See my other post with the link explaining the issue and how to fix it.
Old Jan 22, 2016 | 08:01 AM
calif phil's Avatar
ARP makes a nice stud kit to replace the OEM bolts.
H2Miami's Avatar
In my case I can't smell the exhaust gases so nor worries for now .
Old Jan 22, 2016 | 09:05 AM
mulepic's Avatar
I have an after market exhaust. I'll have to crawl under there and put a wrench on the bolts to see what is going on. But at least I have something to check out. I just assumed it was a lifter or something.
Old Jan 22, 2016 | 09:40 AM
mcioci's Avatar
I did too but once truck got warm and noise went away I knew it had to be something with the exhaust. Thank your stars its not a lifter, much bigger job and costly.
badss98
Jun 22, 2021 09:50 AM
liveinxs
Mar 9, 2020 04:39 AM
register1987
Dec 18, 2015 09:21 PM
Baldfox
Jan 18, 2015 12:42 PM
09 Black H2
19
Aug 19, 2014 05:27 PM
