(Post 235597)
Unscrew the sun visors and let them hang. Peel back the rubber trim molding around the sunroof opening (it's not glued, just press fit). Pop the little cover off each 'A' pillar that says 'Air Bag', using a small flat blade screwdriver. Remove the screw under it, and wiggle out the trim piece. You'll then be able to gently pull down the front portion of the headliner. Don't worry, you can't set off the airbags by bumping or disturbing them. They need an electrical signal to fire the pyrotechnics.:D
water leaking onto passenger floor board...
HI!
I have an '08 H3 Alpha and have had this problem for several months now... I took it to car repair shop and they couldn't get water to leak. However, if bad weather comes with alot of rain the water just poors in! I've read this entire thread but still not sure how to access the drain tubes. Can someone please help with further details??? Thanks! |
