Vibrating Sound
Hi - I wonder if anyone of you had experienced a vibrating sound and/or like air going in a tunnel kind of sound when you run your H2 at 80MPH?
I had this problem ever since I bought the H2. The sounds is coming from the outside - passenger side. First I thought it might be the antenna but then again the sound does not point to that. Any information will be very much appreciated. Regards! Lot |
RE: Vibrating Sound
Sounds like maybe the roof marker light on the passenger side?? See if they are SOLIDLY placed!!
RE: Vibrating Sound
Mine did the same thing. I took it back to the dealer and they removed the two rails along the front window, black piece, and put insulated double stick tape and then put the rails back on. The noise stopped.
Try that. |
