UPDATE: PHOTO OF CARGO RACK & GOBI LADDER ON H2
Hello Friends,
The CARGO CARRIER ROOF RACK and the GOBI LADDER is now completed and installed!
For your pleasure here are the photos.
As always your comments and questions are always appreciated.
[IMG]local://upfiles/4067/6CD5FE869D6F456CB1B8AED2D371F96E.jpg[/IMG]
ORIGINAL: SafariHummerH2
PHOTO OF GOBI LADDER:
[IMG]local://upfiles/4067/F1D6180146F4426C8EFA522E32C9FE6B.jpg[/IMG]
Is that a passenger mount ladder?
I have mine mounted on the passenger side and it lines up with the contour of the roof
I'll upload a pic when i get a chance
Hello Friends,
I not sure what you mean by a "passenger mount ladder"?
The ladders which I'm familiar with are either left side rear mount or right side rear mount.
My ladder is mounted on the drivers side left rear and it lines up with the contour of the roof.
That is why they are manufactured specifically for left side or right side mounting.
Because the contour of the the roof is opposite for the left side and the right side.
I just looked at my new ladders and yes, your ladder is for the passenger side, not the drivers side. Look at the top where it mounts, and you will see what we are talking about.
The left side of the ladder top mount flange has a larger area point for the screw hole which lines up exactly where the original top moulding plastic push plug is on the roof molding.
The right side of the ladder top mount flange has a smaller area point for a screw hole to be drilled out on the vehicles rear door. (which I did not do since I don't want to drill any holes on my vehicle)
However the ladder is very secure and sturdy.
The bottom screws just clamp on to the bottom of the door frame.
Although I knew that this was a left side mount ladder, I tried mounting it on the right side just to experiment, and discovered that the top mounting flange would not fit the top contour of the rear door. And the screw hole of the top moulding plastic push plug would not line up with the ladder.
As per the installations instructions, this hole must line up.
So this ladder is installed on the correct side (drivers side) as per the supplied instructions.
