Wanted to see if anyone else has this problem or had a problem with a 2007 H3 when starting my 2007 H3 in the morning it turns on and runs for about 10 seconds then it turns off by itself I shake the negative cable and it let’s me turn the hummer on again but it only does it to me when the temperature is cooler/cold. Sometimes it takes a few times of shaking negative cable and sometimes it takes only 1 time.
Hello and welcome to HF. I moved this out of the New Member section because.... like it says first post sticky thread at the top: "THIS SECTION IS NOT FOR TECH QUESTIONS!!"
Using my crystal ball of Hummer problems I can see that you still have the stock OEM crappy azzed battery Terminal Connectors. That is "the" problem. Number 1 cause of electrical Gremlins, and beat over the head with numerous threads and posts suggesting people hack them off immediately and replace the stock crap with a quality aftermarket set, like Stingers or your favorite brand.
Seriously, the stock battery connectors are absolute junk, every one of them will fail (not if, only when). Search around hear for battery terminal connector threads, you will see what I mean. When you google "H3 Hummer battery terminal connectors" and check the on line images you get pics of my truck with Stingers in the top of the list.
I have replace the battery cable connectors with brass ones and it worked perfect for a couple of weeks then started to have the same issue again.
