Transmission problem H2
Old Dec 19, 2009 | 09:12 AM
zebblue's Avatar
Post Transmission problem H2
My car will not start from 1st gear when in drive, i have to select gear one and only move into drive once going, the car will also not select 4th gear
the car is H2 2004 with 10,000 miles the red light comes on the dash for engine management, i am in the uk so getting info is pretty difficult, anyone with any ideas
Old Dec 19, 2009 | 01:58 PM
calif phil's Avatar
Do you have access to a scanner? You will need to plug it in and see what the codes are. You might have a solenoid acting up. If no scanner is available try to disconnect the battery for 30 min and reconnect it to see if the problem goes away. Also check the coolant and transmission fluid levels to make sure a trans cooler in the radiator didn't break.
Old Dec 20, 2009 | 01:24 AM
zebblue's Avatar
thanks for the help Phil, i do not have a scanner but i will call out the rescue service as they carry them to check the codes, i will have a go at disconnecting the battery though
i will also check the fluids
Old Dec 20, 2009 | 12:59 PM
calif phil's Avatar
If you still need help I can give you the phone number to a friend of mine who owns a tranny shop in California. I know he would be happy to help you out over the phone.
Old Dec 23, 2009 | 11:58 AM
Hummergb's Avatar
You could try Auto Transmissions in Barnsley - They fixed mine when my drive plate failed.
Bichito
Sep 21, 2012 02:27 PM
scott64
Nov 11, 2011 08:57 PM
mango
25
Jun 30, 2009 04:56 PM
HummerGuy
18
May 5, 2007 02:27 AM
