Transfer Case Control Module
I'm having trouble finding the exact part number for a Transfer Case Control Module (TCCM) for my 2006 H3. If anyone knows the part number, that would be great.
Also, I will be installing it myself and wanted to know how exactly to get to the module. Do I need to remove the right side dash panel and it's right there? Thanks in advanced! |
service manual says , behind the glove box. right side
you can get the manual free, search. |
If you remove the dash side panel on the passenger side it is right there.
Why are you replacing it? |
Originally Posted by TAINTER
(Post 339212)
Why are you replacing it? The problem is that the car is locking on tight turns since the t case is in hi lock with the power distribution of 50/50 not 60/40. |
Originally Posted by TSLevin95
(Post 339205)
broken fork?
(Post 339220)
broken fork?
if you pull cover, get access to it you will have the info you are asking for.i assume its marked.
Update: I installed the new TCCM. The problem still persists.
So I looked a the invoice of when I took it to the Chevy dealer. They told me that the motor encoder and TCCM had to be replaced, this is verbatim what the invoice said: Customer states vehicle will not move when turning RT or left When running towed in Code C0306. Unknown 4WD position control Encoder motor shorted or grounded in control - necessary to Replace encoder motor and transfer case control module $1240.00 Has anyone had experience with Code C0306? I did a little research but I need to do more, but what I found so far is that I need to clean the ground wires that connect to the motor encoder. |
oh boy,
i read "somewhere" that you can pull the motor and check it for proper movement. dont know where? you can run the buttons and see shaft movement. anybody know more? |
