transfer case
I have a 03 h2, bought used, rancho lift kit..
It seems like it's in 4 wd mode all the time, when I turn of pavement it 'hop's, it appears that the wheels all want to rotate at the same rate all the time.. it seems to be putting a lot of unnesasary ware on the truck. any one know if this is normal? any suggestions ? Thanks |
RE: transfer case
Ummmm ... you DO know it's full time 4wd right?? LOL!
RE: transfer case
I understand it is. not owning an h2 before but havedriven/owned many awd/4 wd vehicles it acts likes it's stuck in 'off road mode'.. likethere is no differential, all tires rotate the same amount all the time..
Was wondering if someone had similiar issues, or if this is 'normal' has any one done a conversion to put it into 2wheel drive mode when driving in the city Thanks |
RE: transfer case
Since you have had 4 wheel drives before I assume that you have checked to make sure you weren't in high locked. I don't remember the controls for the H2 but put it 4 high ( not locked )and slowly back up 20-30 feet. Sometimes they don't disengage when you shift out of the locked mode. I have never had a lifted truck so I don't know if that could have something to do with what you are feeling.
RE: transfer case
and since you bought it used.... and modified... you should also find out if someone added a locker to the front...
RE: transfer case
They are always in 4WD... all the time. Maybe you have it in 50/50 instead of 40/60?
