That prompted a thought.
byeatts, do you have a sunroof? Has the area of your front passenger floor been wet? The TCCM (Transfer Case Control Module) is located right by the BCM, they do not like to get wet. If the TCCM goes bad, that also leads to a TC Fail. |
(Post 346999)
Update, I found a broken wire to the axle sensor, Likely ice build up caused it, Splice it and it now shifts into low ,Hi and Hi lock perfectly. So the TCCM does read the Traction control sensor and will cause shifting failures , New one for me! However I still have a Traction control failure light on the dash, Wonder if it will need flashed to clear?
| All times are GMT -5. The time now is 03:41 AM. |
