Tortion Bar Lift Pics
Old Nov 14, 2007 | 05:20 PM
SteveO's Avatar
Default Tortion Bar Lift Pics
Had my Tortion Bars on my07 H3adjusted today from my dealer. Asked him how much?He stated this will be part of the alignment no extra.Hope these pics upload.......
Old Nov 14, 2007 | 05:47 PM
dmb7280's Avatar
Default RE: Tortion Bar Lift Pics
looks awesome, steve! i had mine tighen up about 3 weeks ago and loved it.they shouldtotally come from the manufacturer like that. such a meaner look!
enjoy!
lil d
ps -i speak in past tense as my ride is totaled
Old Nov 14, 2007 | 05:52 PM
HummerGuy's Avatar
Poor dmb[&o](I don't know your name either).
We feel for you buddy. I hope you get your reincarnated Old Blue soon (I think it was Old Blue)
Old Nov 14, 2007 | 05:58 PM
SteveO's Avatar
David,
Yeah ..........sorry to hear and I alsoseen the pics ofyour misfortune, good thing your ok. Are you going to stay with the H3 when you get a new ride?
Old Nov 14, 2007 | 06:10 PM
2zRescue's Avatar
You ride is WAY too clean!
Old Nov 14, 2007 | 06:18 PM
SteveO's Avatar
ORIGINAL: 2zRescue
You should have seen it before the dealer cleaned it.
Old Nov 14, 2007 | 06:23 PM
smokinhummer's Avatar
Your dealer cranked up your torsion bars for you as an alignment? I go tommorrow to test fit my new wheels and tires and was quoted $225 for the offroad shop to tweek the bars and realign (if there are any clearance issues). What did your alignment cost? Maybe I should go to my dealer first.
Old Nov 14, 2007 | 06:41 PM
SteveO's Avatar
ORIGINAL: smokinhummer
Smokin.
The dealer charged me $135.00 for the full deal..You know it's funny, when I asked another localdealer about adjusting the tortion bars theysaid they would not do it because it will cause to much other issues.My dealer that I deal with andalso bought my H3 from did it with no problems and even stated to me that I have nothing to worry about. He said you just may get a bit harsher ride.The condition of the ride hardly can be noticed. Ireally like the look alot better now.
Old Nov 14, 2007 | 07:35 PM
Camou2's Avatar
I am not considered mechanically inclined by any one I know but I do believe that cranking up torsion bars should be done cautiously. When I asked my dealer about cranking up mine on the Alpha which has 20" rims and 35" tires his advice was to install a front lift kit. When looking at my options I found an article on torsion bars andhave included some it herefor whatever value (figures wouldnot paste in) it mayhave in making a decision to crank up the bars or install a lift kit. I installed a lift kit.
Understanding Torsion Bar Suspension
A torsion bar suspension system uses the properties of elastic twisting action in a bar of steel to provide suspension. This method is popular on many trucks, because it provides for ample clearance for the front drive shafts and thus makes packaging of the front suspension much simpler on a four-wheel drive vehicle. It is important to remember that a torsion bar is simply a spring, just like a more conventional coil or leaf spring that you may be more used to seeing on a vehicle. Most torsion bar suspensions use an adjuster called a torsion key to facilitate installation and ride height adjustments.
Torsion keys are used to adjust the orientation of the torsion bar in relationship to the lower control arm of the suspension. This adjustment is necessary because unlike a coil spring, the initial ride height of a torsion bar equipped vehicle is not obvious. Also, the exact twist of a torsion spring can have a large effect on the ride height of a vehicle. In our testing, we have found as little as 3 degrees difference in twist can affect the ride by as much as one inch.
During driving, the load path of the front suspension of a torsion bar equipped truck passes through the tire, the spindle and the lower control arm, down the torsion bar, through the torsion key and down through the torsion key adjusting bolt and into the cross member of the frame. In other words, the entire load of the front of the vehicle is riding on the torsion key adjusting bolt. See figure 1 for a diagram of a torsion key and bolt
Figure 1 – Torsion Key at 0-degrees to adjusting bolt
Drawing supplied by General Motors
The amount of load carried by the front wheels varies from model to model, with the diesel powered trucks weighing more than their gas powered cousins. Other variables include the optional equipment that might be installed on the front of a vehicle, such as winches, large bumpers or snowplows. (It should be noted that any extra weight would only aggravate the load on the front suspension, as well as increase the rake of the truck at rest).
To calculate the actual load on the front suspension of a modern truck, we will make a few assumptions. Let us assume that our sample truck weighs 5000 lbs, and that 60% of the weight of the vehicle is on the front axle. The control arm has an average length of 20 inches to the center of the wheel and the torsion key has a length of approximately 5 inches. This gives us a ratio of 4:1 for the leverage between the control arm and the torsion key. In figure 2 we can see that this gives us a static load of 6000 lbs on the torsion key adjusting bolt.
FrontAxleLoad = 5000lbs x 60% - 3000lbs
WheelLoad - 3000lbs / 2 = 1500 lbs
PressureOnTorsionKeyAdjustingBolt = P - 1500lbs x 4 - 6000lbs
[left]
[b][font=arial] Figure 2 – Calculation of pressure on
Old Nov 14, 2007 | 09:44 PM
When you say lift kit, do you mean like a ready lift?
