Tires
Old May 17, 2011 | 04:31 AM
Weston's Avatar
Default Tires
What Tires Can I Fit On 22 X 14 Size Rim?
(List Please)
And Is It Possible To Run These Width Rims On A 4 Inch Tuff Country?
Yes, No - Please State Why (Any Ideas, Fabrications?)
Thank You
Old May 17, 2011 | 05:18 AM
Bullwheel's Avatar
Look at www.westkycustoms.com
They use the 325/50R22 tire on 22x14" rims (overall diameter 35")
A 4 " lift should be necessary....not sure if you could use then also a tire 40x15.5x22???
One thing is sure...it will stress your drive till to the limit and maybe over.
The wheels will stick out if not better run beside your H3...could be an issue with the police...
Old May 17, 2011 | 10:08 AM
Weston's Avatar
I really love the deep dish look. But if I update the gearing wouldn't that help out my bearings alot?
Old May 17, 2011 | 10:22 PM
Bullwheel's Avatar
I think there would be a lot to upgrade...
Just compare the weights of the current set up (tires & rims) and what you plan for...then you will understand.
Anyway if you do it stay with the 35" diameter....40 would just be too much.
Kepp also in mind that such a big tire means a lot of grip. In certain situations the grip of the tires may be so good that if you hit the pedal in 4lo your drive shaft snap as it happened to me once before in a Wrangler.
Old May 18, 2011 | 03:24 AM
Weston's Avatar
So 20x11/12 on 35 tires would be max? Cause after vacation I'm really going to put time and money into my h3
Old May 18, 2011 | 04:56 AM
Bullwheel's Avatar
You mentioned you want to go for a 4" lift... After that your back space is set to max 4.5"!
Asume that you take the 12" rim it would mean that min. 7.5" will obstruct from the mounting surface....that will make your truck a monster!
Hope you post some photos after transformation?!
Old May 18, 2011 | 03:38 PM
Weston's Avatar
I really want a deep dish rim, but everything seems complicated. But ill make something work, and yes after I come back from New York she's getting all the attention, and of course pictures going up through the process and final.
Caraddict
57
Mar 28, 2018 12:42 PM
Pelvicthrust
Sep 28, 2012 10:52 PM
Pelvicthrust
Sep 26, 2012 11:06 PM
smokemaster60
Sep 7, 2010 04:56 PM
05roush0090
Oct 30, 2009 06:51 PM
