Tire Rotation
can someone gimmi some info on tire rotation? i see it mentioned alot here.
usually what i do with tires with my other cars is, since the engine is at the front and its heavier and front wheel drive, the front tire usual wears 2x faster. i put the back tires at the front, and put new tires on the back. so only changing 2 at a time. i dont know if its better or worse but its what ive done. but sounds too cheap too do it on a hummer haha |
Rear lh tire goes to rh front and rear rh tire goes to lh front...then drop the fronts straight back to the rear. I've rotated mine every 5000 miles so far and the tread wear is really even. I have 15000 miles on my H3 (oem tires show very little wear) and I am looking to get some better tires for snow.
The whole tire rotation takes me about 30min with a floor jack, 2 Jack stands, air driver, and a torque wrench. |
you say lh, rh Tyre.....so i assume i can just take the whole wheel and exchange around? cause its identical. haven't really looked. cheers btw. really helpful
Originally Posted by joewcob3
(Post 208285)
08H3 is dead on with his comment.
As Homer would say, "dooooooohhhhhh!!!!!!!!!!"
you are right...I crossed the wrong ones. Thanks for the reality check! |
Happens to everyone at one time or another.:D
