Thermostat replaced, how fill the system getting out all air bubbles
Old Mar 13, 2018 | 06:24 PM
Coloh2hummer's Avatar
Default Thermostat replaced, how fill the system getting out all air bubbles
i just replaced the thermostat and now I need to fill the radiator and of course getting rid of all the trapped air
Old Mar 14, 2018 | 07:50 AM
calif phil's Avatar
Once the radiator is filled, It should do it on it's own. Turn the heater on high, run the motor and watch the temp gauge rise, the thermostat will open and the temp gauge should fall to normal. Make sure to keep the reservoir filled about half way. If your heater is producing good heat then you have sufficient coolant flow.
Old Mar 15, 2018 | 06:08 PM
Well, that's the other problem I have....The selector for the heat/ a/c is stuck on defrost!
rmach3
Apr 28, 2016 05:50 PM
OingoBoingo
Feb 3, 2009 10:29 AM
cnynctry
Mar 6, 2008 09:33 AM
vger105
20
Dec 31, 2007 01:51 PM
machines
Mar 1, 2007 07:21 AM
