Temp gauge running 5/8 to 3/4
Old Apr 26, 2018 | 05:08 PM
Kknox's Avatar
Default Temp gauge running 5/8 to 3/4
I have 2007 h3 i5, I've been noticing my temp guage running between 5/8 to 3/4. All the time. Change radiator, hoses, coolant and thermostat. I can't figure this out, it's only been in 70s here in ga but I'm afraid of when it gets really hot. I've heard a extra trans cooler may help.
please any advice will be greatly appreciated
Old Apr 26, 2018 | 05:42 PM
650Hawk's Avatar
H3 Gauges are notoriously inaccurate. While mine always runs right at the 1/2 point on the gauge, others have said they run at 3/4. Without a scangauge, or an OBD adapter and a scan app (like Torque), you have no idea what the actual running temps are.
Is this a new situation? Did it used to run at 1/2, and now runs at 5/8-3/4?
Old Apr 26, 2018 | 05:47 PM
Kknox's Avatar
I never payed attention until recently when I had trans rebuilt
Old Apr 26, 2018 | 05:51 PM
JerseyCoast's Avatar
I have an 07 as well .Always ran just below half mark. Over winter my t-stat went bad, stuck open .since replacing that I have had similar issue ( post is below here ) . When I stoo at traffic light, I go to 3/4, when moving back to just about half.
My actual readings at half are 203, at mid way to 3/4 line, it's 212,. At just below the 3/4 mark it's about 219 .
You need to read actual temps and not trust the guage . But I understand your problem as mine was always fine, until recently, now it's all over the place as well.
Old Apr 26, 2018 | 05:54 PM
Kknox's Avatar
Lot of mechanics keep telling me that hummer are supposed to run little high but I'm worried when it gets really hot here in Georgia
Old Apr 26, 2018 | 06:38 PM
Catdaddy's Avatar
I have a 2007, used to say 1/2 after I had a new radiator put in its at 3/4. I live in California and it can get hot, never had it overheat since new radiator, going on 2 years.
Old Apr 26, 2018 | 06:40 PM
Kknox's Avatar
I hope not,
I want to thank you all for answering and help
Old Apr 26, 2018 | 11:36 PM
happythree's Avatar
had an 07, now a 10. both never got up to mid point. top temp hit 205 even with a blanket over the grill on a hot day...if everything is working right.....its cool!
btw, in 58 yrs of driving 35 cars ive never changed a fan clutch.
Old Apr 27, 2018 | 06:52 AM
Ordieh's Avatar
Temp can be dropped several degrees by adding PURPLE ICE to the DEXCOOL.
Old Apr 27, 2018 | 09:09 AM
For about the 2 millionth time..... 3/4 on an H3 temp gauge is 100% completely NORMAL. Feel free to search this, it has been beat to death.
The gauge in the dash is like an idiot light with a needle. When it is in the red, then be concerned. Otherwise, drive on and find something else to worry about.
If you mud bogged your 3 and got dirt and crud up in the radiator, rinse it out, even use some mild soap then rinse it thoroughly.
JerseyCoast
Aug 18, 2025 09:47 AM
giant H2
Sep 28, 2009 05:14 PM
meero
May 28, 2009 10:37 AM
Koboss
Mar 3, 2008 10:48 PM
jonhbryson
Aug 28, 2005 02:11 PM
