TC and ABS Lights
About 3 months ago my ABS and TC lights came on, I have tried resetting them and nothing.. Last week I replaced the Front Hubs and Bearings on both sides as well as the ABS sensors.. It does not change into 4wheel low which I am guessing is because of the error... I was wondering could this possibly be from bad ABS Sensors on the rear or is there another issue I should check as well...
Also I ran a Diag this morning and got the following 2 codes.. Just any feedback that might help would be appreciated... I did look them up and it says the sensors BUT it also says it could be more issues than just those... I just simply thought I would throw this question out at the same time... P0332 P0420 Thanks in advance, |
[QUOTE=Crash Gear;302251]About 3 months ago my ABS and TC lights came on, I have tried resetting them and nothing.. Last week I replaced the Front Hubs and Bearings on both sides as well as the ABS sensors.. It does not change into 4wheel low which I am guessing is because of the error... I was wondering could this possibly be from bad ABS Sensors on the rear or is there another issue I should check as well...
Also I ran a Diag this morning and got the following 2 codes.. Just any feedback that might help would be appreciated... I did look them up and it says the sensors BUT it also says it could be more issues than just those... I just simply thought I would throw this question out at the same time... P0332 P0420 Thanks in advance, 2003 H2 |
