TB Lift
First post on this forum, new owner of an 06 H3. I hated the cat in heat stance so I did some research on cranking up the TB's. Worked great, I turned the passenger side 2.5 turns and had to turn the drivers side 3.25 turns to level the car. I never have liked the feel of the front end, now with it raised it seems more crisp. The total amount raised is about 2.5 inches. looks much better! I know this is old news to some, but it's new to me. The alignment is unchanged. Very happy with the change!!!
RE: TB Lift
Welcome and thanks for your input.
The alignment may not of changed as it seems..but it did..if you don't have it re-aligned soon, you will begin to notice more wear on the tires on the outside edge of the tread... |
RE: TB Lift
I did have it checked...there was no change needed. Sounds strange, but is true!
RE: TB Lift
Hmm..Okay, well that's cool then..as long as you had it checked, that's the main thing.;)
RE: TB Lift
OBTW...I like the SIG...Retired Air Force! ;)
RE: TB Lift
I had my the frount end re-aligned. It runs better at 70 mph before it wanted to drift.
It was still within factory specks but not by much. My were turned 3.25 driver 2 passanger. Also I'll take the 1911....... |
RE: TB Lift
Welcome:)
RE: TB Lift
ORIGINAL: Midlifetoy I did have it checked...there was no change needed. Sounds strange, but is true! Did you have the dealer check the alignment, or a specialty shop? |
RE: TB Lift
1 Attachment(s)
RE: TB Lift
Thanks for the welcomes.
A specialty shop checked it. SIG as in signature, not SIG as in boom! :D |
