T-Case stuck in 4 wheel low
Hey All,
I'm new to thses forums and I have 06 H3. I did some searching but couldn't find anything regarding this. I did some wheeling today and engaged 4 low, and now it wont shift out of 4 low. I have used 4 low in the past and had no problems going back to 4 high. I have tried everything and it simply wont shift out of 4 low. The light never blinks when I push the button. I spent arounf 45 min trying everything with no success. The car is stuck in vail at the moment so any advice you have would be greatly appreciated. |
RE: T-Case stuck in 4 wheel low
did you try going in reverse about 5-10 mph while turning left and right...this should kick her out of 4-low. If not, try going under and unplugging the plugs on the t-case.....clean em out then plug it back in. This connector has given people problems in the past.
That's good advice. One thing is that there is no feedback if I push the buttons. They never blink or anything when I push them. I'll do what you mentioned because I did go through some water and mud after going into 4 low. Thanks again.
it may be the switch,i know i had a similer problem on my truck
So... did that fix it?
I know this may be the obvious but I will ask anyway. Are you putting it in neutral before putting it in low lock?? It needs to be in neutral.
So...did it work?
I vote TCase plug fart, might have got gerdoo in the connection, or loose. The switches can go as well? Any luck funkDoc?? ?????
when i switched switches,it fixed it,but not sure in your case
also, make sure the button isn't stuck. It happend to me that way...i must have pushed the button sideways a little, and it got stuck. I felt like an asshat when i figured it out...lol
| All times are GMT -5. The time now is 09:08 AM. |
