still loosing coolant
a month after a new rad i am down over an inch. its slow but sure as i check daily a small amount???
Just found my thermostat housing leaking.....tightened bolts.....all good....might check.
tnx, ill check that, hope it is!!
water pump?
dropped front skid plate and for first time saw orange fluid on center rear below water pump.
im guessing its the pump. any advice is appreciated. |
need good new pump
i should have asked about the pump,any opinions on a good one ? since i only want to do this once!!
im at apx 60000 and it seems early for the oem pump to leak. its a big job for me so i want to get a good one and get ready for decent weather to do it. any comments welcome... |
AC Delco (OEM) from Rockauto.com - about $35.
ok, i got my rad there but last week i tried their site and could not get to a pump!! sometime i just need to give up and try later!!
thanks,,, on site,,,found pump,,,cant see how to order,,, ACDELCO 251731 {#12620226} OE Design; Stamped Steel Impeller GM Original Equipment; Includes Gasket http://www.rockauto.com/catalog/images/us.gif http://www.rockauto.com/catalog/images/ca.gif New bolts must be ordered when a new water pump is ordered, bolts are torque to yield; Includes Gasket i give up!! i got a phone # so i can call. |
