Started up H3, a plume of smoke from exhaust.
33K miles. Recently serviced (oil change). Started vehicle. Plume of smoke on start up. Nothing thereafter.
Any ideas what this could be? 2010 Hummer H3 Alpha. Thanks. |
What color was the smoke? What was the approximate temp?
Rule of thumb, blue smoke is engine/tranny fluid and white fluid is water vapor/coolant If it was a 1 time thing it could just be normal but if its a reoccurring thing then you could have a possible leak. |
Want to say it was white. This is the second time in a month.
Weather Temp? LA, so Saturday it reached 85º and went down to 50º at night. Was roughly 74º when it took place yesterday. Truck had been sitting for 3.5 hours since its last drive.
Originally Posted by RickStang
(Post 294032)
I want to say your burning coolant but thats not a proper answer to your question.
You could have a possible small head gasket leak or a crack in your head. Next time you should get someone to start your car and go smell the exhaust. If it smells sweet then it is coolant. |
Rick, thanks.
Still under warranty and hope this is covered. Problem for me is the local dealerships are terrible and I have to drive 100 miles to get to one that knows what they are doing. |
I'm bett'n moister in gas.
Chris |
Sounds like condensation in the exhaust being pushed out during the engine starting process to me. A 20 degree difference in temprature can create a lot of condensation, let alone the 35 degree temp change you described.
Originally Posted by TAINTER
(Post 294058)
I don't know about a "plume" but a slight puff of blue smoke when stepping on the gas the first time after a cold start is normal.
I recently had the head replaced on my 06 H3 with 78k miles. The day I got it back it had been sitting for about 8 hours in below freezing temps before I tried to start it. when I started the engine it poured blue smoke then the check engine light came on. after letting it run a few minutes the smoke cleared. the truck runs good and has only done it a couple of times since I got it back. Chevy dealership that did the work says engine light is from loose timing chain. I am wondering if I should unload it before it cost me more money.
