So many problems... Help!
Old Apr 21, 2014 | 10:21 AM
Originally Posted by samijane
YES!!! I've actually had terrible leaking! And I'm pretty sure I have the original connectors. I'm the second owner so I will contact the first to check
what would the driver side carpet getting wet have anything to do with the battery? The passenger side doesn't leak, it does every once in a while but not frequently.
Water intrusion into the passenger side front behind & to the right of the glove box has nothing to do with the battery itself, but it has everything to do with your problem If you got your BCM (Body Control Module) wet from your plugged sunroof drains, it then shorts out, drains the battery, and freaks out the body electrical. Think of it like getting your cell phone wet, maybe the first time you get lucky and it keeps working (for a while), next time or two it gets wet = toast.
Search the fix for leaking sunroof drains, get that taken care of. When the water stops, and your BCM is 100% dry, then see what problem is left behind.
samijane
Apr 18, 2014 07:58 AM
Dennis
Head and Valve Problems.
245
Dec 17, 2013 11:22 AM
rtwash
Dec 13, 2013 10:45 PM
DougandBeth
23
Dec 26, 2009 02:59 PM
Nov 24, 2009 06:29 PM
