small problems or quirks?
Anyone having small issues or little quirks with their H2?
I have an 03 with 60,000 miles and have had a few little issues! Nothing major though. rear leveler on the air suspension. 249.00 to fix at dealer. seat memory module **** its pants on the drivers seat. 191.00 for parts. fixed myself. ( have to stand on running boards with head upside down on floor mat to see this one!! Had green wire break on the gear shift selector that does not let key release from the ignition when this one happens. soldered back together and reenforced myself. 0.00 other than that , no real issues. Just checking to see what others there may be or alert other to these little problems. Keith |
RE: small problems or quirks?
ORIGINAL: aycedad Anyone having small issues or little quirks with their H2? I have an 03 with 60,000 miles and have had a few little issues! Nothing major though. rear leveler on the air suspension. 249.00 to fix at dealer. seat memory module **** its pants on the drivers seat. 191.00 for parts. fixed myself. ( have to stand on running boards with head upside down on floor mat to see this one!! Had green wire break on the gear shift selector that does not let key release from the ignition when this one happens. soldered back together and reenforced myself. 0.00 other than that , no real issues. Just checking to see what others there may be or alert other to these little problems. Keith I'll try to bring it in the garage today and let them check it with the Tech II hope no biggy ,cause for sure they have to order the part's from the US :( oh yea forgot to tell...... I'm in Germany Volker |
Keith,
I've had my H2 for about 3 months it's an 03 with 29000 miles. So far since new it's had seat memory module, 2 driveshafts (rear) and left Mirror. Then since I've owned it it's had both front door panels (paint peeling, light lenses falling off), radio knob (peeling), left front axle seal (leaking @ diff.), idler arm and pitman arm (loose), transfer case removed to replace a leaking seal (between transmission and transfercase), winshield moldings resealed for the 60mph wind noise and the left washer nozzle replaced (kept popping out). DWP99 |
Whew on the second 1 - must have been traded for a reason. Thank the stars for warranty work.
As for the air suspension - mine leaned way to the drivers side and then eventually went all the way down in the back. Was just a leveling sensor.!!! Good luck to both of you!!!! |
i broke a tie rod on the curb at the mall once. really messed up my alignment
ORIGINAL: shortbus i broke a tie rod on the curb at the mall once. really messed up my alignment |
they don't have the video, so i'm not worried. [sm=badbadbad.gif]
ORIGINAL: vkh2 ORIGINAL: aycedad Anyone having small issues or little quirks with their H2? I have an 03 with 60,000 miles and have had a few little issues! Nothing major though. rear leveler on the air suspension. 249.00 to fix at dealer. seat memory module **** its pants on the drivers seat. 191.00 for parts. fixed myself. ( have to stand on running boards with head upside down on floor mat to see this one!! Had green wire break on the gear shift selector that does not let key release from the ignition when this one happens. soldered back together and reenforced myself. 0.00 other than that , no real issues. Just checking to see what others there may be or alert other to these little problems. Keith I'll try to bring it in the garage today and let them check it with the Tech II hope no biggy ,cause for sure they have to order the part's from the US :( oh yea forgot to tell...... I'm in Germany Volker thank's for you'r respond Volker |
Glad they found the problem!:)
Ive gont through 3 sets of mirrors on my 03... they don't seem to like the cold up here in AK. Are the new style mirrors retractable... are they working any better than the crappy design that I have?
