Skew H3
Old Apr 30, 2010 | 12:56 PM
Banan's Avatar
Default Skew H3
Hello
I have strange problem with my H3 (2008 model 3,7L). Is litle bit skew to left side when you look from back side. I check hight and this is resaults:
Front:
Left corner bumper to ground 31,8 inch
Right corner bumper to ground 32,3 inch
Left wheel from top to fender 5,2 inch
Right wheel from top to fender 5,5 inch
Rear:
Left corner bumper to ground 32,3 inch
Right corner bumper to ground 33,1 inch
Left wheel from top to fender 8,6 inch
Right wheel from top to fender 9,25 inch
It's look that diferent between left am right side is front 0,4 ich and back 0,8 inch is not that much but is visible
What is the problem, what can i do to fix it?
With driving is no problem , he go straight, no crash or something.
Old Apr 30, 2010 | 02:13 PM
Sugarphreak's Avatar
Originally Posted by Banan
Front:
For the front you could crank (tighten) the torsion bolt a few times under the left side until you get the two heights the same...
Not sure what you can do about the rear. It should still be under warranty right? Maybe have the dealer make the adjustments for free?
Old Apr 30, 2010 | 04:41 PM
Banan's Avatar
With front i will tray tomorow, than i look and measure again rear. But first i have to find real flat surface.
Warranty and dealer hmmm is very havy stuff in Europe, they are very expensive. And are only few with real and only Hmmer service, rest is mulit brand , and Hummer is like 5-th wheel, beter to do by self, or go to USA car garage.
But in rear is posible to adjust suspension? In this year i want lift front and change shock's front and rear
Old Apr 30, 2010 | 06:17 PM
jayhawkhummer's Avatar
Unless I'm mistaken, if you crank up the passenger front, it will "lower" the driver rear. Crank the driver front and it will lower the passenger rear. Worked on my pick-up anyway.
Old May 1, 2010 | 04:14 AM
Banan's Avatar
Cool, thx for help.
