-   -   size body lift for 37s? (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/size-body-lift-37s-33855/)
MrYoungMud Sep 22, 2014 05:44 PM
I have a completely stock 2005 hummer h2 (stock tires are 33" BF Goodrich all terrain Baja Champions) and want to put 37" Nitto trail grapplers on. Money isn't unlimited so I am looking into a body lift because they are less expensive than suspension lifts. Looking to do maybe a 3 inch body lift with leveling kit. Will this be high enough for the 37s? Also what brand is good? Thanks.
P.S. I am looking for a 10000-12000lb winch to put in a cradle mount in the 2in receiver in the front. What winches are good and reliable for about $600? Brands like traveler, superwinch, or smittybuilt?
LoJac963 Sep 22, 2014 09:33 PM
Stock are 35's, 37's fit many 2's just fine without any lift other thank maybe some cranks on the keys.
MrYoungMud Sep 22, 2014 09:40 PM
Thanks, so I should definetly be safe with a 3" kit. Also any opinion on a winch. Thanks.
LoJac963 Sep 22, 2014 11:56 PM
3" would be plenty. I think some guys on the other forums run upwards of 40" tires with 3" lifts/body lifts on theirs. As for a winch I couldn't tell ya. I've been wanting to get one but haven't given them much thought.
Dieseldrums Sep 26, 2014 09:13 AM
I would go with a 2" body lift maximum. 3 will be too much. You will have some huge gaps between your bumpers that will look like sh!t and prob see the mounts themselves with a 3. Plus it's way overkill just for 37" tires.
citiboy Sep 26, 2014 09:32 AM
2 Attachment(s)
38" MT tires with 1" body lift, GM green keys cranked 2" and 2" rear coil spacers.
Attachment 11867
Attachment 11868
Allterrainblue07 Sep 29, 2014 06:06 PM
Citiboy, question I want to get 37 X 13.50 X 17 (or 18) Toyo M/T, would I have any problem mounting the 13.50 wheels, not planning to lift it, keeping it stock.
Dan
citiboy Sep 29, 2014 08:22 PM
I don't think you'll have a problem with the 37's on a stock 17" wheels. With the 38's, i still have light rubbing on the frame at full lock, even the stock tires rubs at the sway bar.
Indy Oct 2, 2014 04:44 PM
3" body lift wont be simple on an H2 (don't even think they make one). I would just do keys and small spacers...you'll easily be able to fit 37s with that, and it's cheap.
azeeez221 Oct 3, 2014 01:42 AM
Just put the 37" without any leveling .. the tires will fit anyway also the 37" will make ur h2 higher than your 33"
