-   -   service tps...? (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/service-tps-39179/)
happythree Dec 25, 2017 07:19 PM
service tps...?
ive had a low tire and symbol but not "service tps"
ill search but any ideas accepted.
? svc tpm i think!
Happy Hummer Dec 26, 2017 12:06 AM
Had that half the way home from family tonight. Very cold here.
happythree Dec 26, 2017 09:41 AM
when i have a low tire i get the symbol and, i think, "low tire", not svc tpm. am i forgeting? !!
ill check air when its warmer!
Doc Olds Dec 26, 2017 10:35 AM
Its cold, air up all the tires to 38PSI (at a time when the vehicle has not been driven for a couple hours).
Happy Hummer Dec 26, 2017 12:29 PM
Ho,Ho, Ho.... baby it's cold outside lol!
Mine did display "SVR tpms, tire symbol "
Man it's -3* right now for us and that's pretty freaking cold.
happythree Dec 26, 2017 04:14 PM
ok guys,,,brain phart!!
i got the low one and im good...thanks
82Toy Jan 7, 2018 12:04 PM
I've had this message show up when ever the temps get down to 10 or below degrees. Thinking just ten year old sensors, light goes out once tires warm up.
hummerz Jan 7, 2018 04:14 PM
What does 10 year old sensors have to do with temperature?:confused:
It's a fact that temperature affects pressure.
For every 10degrees drop in temperature, pressure drops 1psi.
I learned many years ago to raise my tire pressure to 38psi, and I never had a tpms light on during the winter since.
I check my tires when it is warm outside, so I do not recommend setting the pressure to 38psi when it is below freezing.
example: @70degrees 38psi
that same 38psi will be at 31psi @0 degrees
if you set to 38psi at 0 degrees then your tires pressure will go to 45psi at 70degrees.
colorado Jan 7, 2018 07:09 PM
just curious, does the spare tire have a TPS in it? Had to put on the spare and got the tps sensor warning. all at 40 PSI
happythree Jan 7, 2018 07:37 PM
not in my spare, rubber stem, not metal.
tps stem is metal.
