Service 4wd
My h2 have the service 4wd light on on the dash
When i press the 4wd button on dash. Light flases then go off. And nothing happend 4wd not engage same goes for 4wd low and 4wd hi. I buy my self new dash swich. Install. Same result. Service 4wd on dash . And 4wd not engage I buy the tranfer case motor. But i have not install yet. I read some where that this problem maybe on the tranfer caseodule. Some time the connections get dirty. And all you have to do is clean them up. Any way any sugestion |
I just went through this on a Tahoe I bought and the transfercase motor fixed it. Buy an AC delco part The cheaper Dorman and ebay type motors are not good.
(Post 339840)
(Post 339840)
The messege on dash is gone now. Light on #4 on swich is on. 4 lo & 4 hi not working. The light flash the turn off. 4wd not engaging. I buy the ebay motor i think is dorman |
I judt install the new motor. The service 4wd messege is gone now. But no 4 lo or 4 hi work. Thw switch flash. Then go off. And nothing
The motor i get was from ebay. I think it was a dorman |
I had the same thing happen when I bought my truck. It would flash and then switch back to regular. It stopped on it's own after I replaced the battery. Been working ever since (1.5 year ago).
Originally Posted by Malcolm745
(Post 339937)
I dont think the motor is the problem now. since is brand new. how come. I can not pay again for another motor. . how about the module. under the steering can that be a problem.
just gussing |
If the SERVICE 4WD message is gone then it is possible the motor is not engaged correctly with the transfer case gear. remove the motor and be sure the motor and transfer case gear line up and go together correctly. If the transfer case was not in the same position as the new motor will be a problem. Sorry if you know all this already!
You should check that the t-case will shift manually. With the motor off use a wrench on the shaft and see if it will shift into all ranges. Could have an internal problem with t-case.
