rust problem
Old Sep 2, 2013 | 12:28 AM
egroegart's Avatar
We scrub and spray the underneath every time we wash the hummer which is once a week. Sunday is our washing day. It takes us usually between 4 to 6 hours to completely wash, vacuum and detail it. Instead of football on Sundays we clean the hummer. In the winter, we spray underneath almost every day. No rust at 147,000 miles and we are in Ohio. Lots of salt here.
Old Sep 2, 2013 | 04:50 AM
Aussie H3's Avatar
Looks like surface rust only to me nothing serious, just give it a bit of a clean and spray some rust preventative or put a coat of paint on it after a wire brush.
Old Sep 2, 2013 | 08:43 AM
happythree's Avatar
Default oops!
rust bullet says you can use a top coat of your choice.
this report did that. from a user on the amazon website,
I had a lot of underbody work to be done on a car I purchased, where rust was evident on the underbody near the doors on each side of the vehicle. I researched for better methods of treating the rust and decided on Rust Bullet.
I removed layers of rusty metal where needed, removed loose rust on other places and ground the metal outwards from rust areas until I hit solid non rusty metal on all areas to be treated. Rust Bullet claims that it dries out the rust and seals everything and prevents new rust. I normally would have converted what rust was left at this point, but thought I would follow Rust Bullet's recommendations on application to let it "do its thing". I applied two coats.
I then coated Rust Bullet with 3M underbody coating.
I found that Rust Bullet does stick to properly prepared surfaces well.
Now, after two years, I checked the areas, and found some places that were not even, so I checked them. Upon pushing in with a screwdriver, I found that these were bubbled areas of rust. I continued to scrape, hoping that this would be a localized area. The more I scraped, the more I found that the Rust Bullet was sticking very well, but everywhere I removed Rust Bullet, I found a nice uniform layer of rust underneath it. It's sort of like Rust Bullet is sticking to an immediate thin layer of metal below it and maybe keeping that from rusting, but below that the rust continued to form and eat into the metal.
Also, upon application I coated much area that did not have any rust, but now it is all rusty. Rust Bullet did not only *not* stop an existing thin layer of rust, but did not prevent new rust from forming. Due to the amount of rust I am finding, it seems that it started rusting shortly after I applied Rust Bullet.
So, by depending on the claims of this product, my work was wasted and my car is rusting out again.
After I now remove the underbody coating and Rust Bullet, I will removed all loose rust, use a true rust converter, then paint and coat the metal to protect it.
So, I would not recommend Rust Bullet for stopping rust, but would recommend using a true rust converter then properly coating the metal to seal it. Although, if the Rust Bullet I have left in the can is still good, I may use that for the top coat of paint as it does seem to stick well.
sooo, the jury is still out!.
I saw a car with a thin coating applied at the factory with the same trapped rust under it eating it till it was junk
Old Sep 4, 2013 | 10:37 AM
happythree's Avatar
Default frame water?
yesterday I looked under and things look good from earlier rust conversion brush on stuff.
curious, I rolled some paper towel and stuck it in the holes on the side of the frame. ! got soaked on the pass side near the front! im not "leveled" and was parked slightly downhill. when I turned around I could see some dripping so it lays in there near the front. thinking of drilling a few small,tiny, holes.
maybe lifting the front has merit after all!
im sure the frame will be there long after it sees the 'boneyard"
jen813
May 31, 2011 10:42 AM
Ricard350
Apr 8, 2010 08:12 AM
Mastiff
Dec 19, 2007 08:12 PM
cspringsh3
19
Feb 22, 2007 06:26 PM
HummerGuy
Feb 20, 2007 10:53 AM
