Removing Lower Grille
Can anyone here confirm how to remove the lower front grille (plastic grille right below the larger chrome upper grille)? It appears it is just held on with clips, but I though I better confirm before I start prying it off...
Also, if it does just pry off any recommendation on where to pry it from? Thanks |
Open the bonnet (hood) and you will see some clips on the back that you need to squeeze together with pliers,then push the grille down towards the ground it should come very easily.
Thanks for the input... I'll be giving it a try later today!!!
No problem mate it is real easy it should take you less than five minutes.:)
