Removing Front Grille
I did a couple searches but can't seem to find what I am looking for...
I have a 2008 H2 and need to remove my front grille. I was looking for a write up/instructions from anyone who may have done this. I see several tabs and bolts, but want to make sure I am not missing anything before I do this. Any input appreciated!!! |
Hi mate if its the same fit as a 2005 which i believe it is then it is very straight forward.You will need to loosen the 10mm silver bolts on the back of the grille.There is also a couple of tabs which you have spotted and squeeze them closed with a pair of pliers.Start from one side and work across pushing grille slowly from behind.Sorry it is not more technical but it really is a 10 minute job and easy to do at your front door just give it a go.:)
One of the 10mm bolts is stuck. I can get the other 3 off except that one, any tips?
