Removing door panel
Anyone here ever removed their door panel? My passange mirror has had a pretty bad scrape onit since I bought the truck. Being that it is plastic I don't believe it can be fixed so I am looking to put on a new mirror.
The instructions seem pretty easy, just wondering if anyone has removed theirs before and if there is anything I need to watch out for. Thanks in advance!!! |
Originally Posted by mgurgone
(Post 229077)
door removel
Ijust replaced both my mirrors ,,make sure the glass is up all the way before you start. i used a flat bar to get under the pannel a little more to help pop the clips loose , mine were on really tight , but once the first clip came loose the rest came off ok ,when you pull the pannel off and remove the wiring , you will have to peel back the insulation on the door , i used a puddy knife , and i was able to reuse it , like above , 2 beers ..
if you do a search on mirrors on this board there is a link with pics to help you out . but it can be done i saved 500.00 over having the dealer do it ....mike |
| All times are GMT -5. The time now is 06:14 AM. |
