remote starter problems
Hey there everyone i just got my first hummer . its a 2006 yellow h2 and i was hooking up a remote starter / alarm but the only thing left is to hook up the bypass to to passlock module . but the only problem is i cant find the darn thing can anyone help me with this.
RE: remote starter problems
Your pass lock wires are usually located in the steering column wiring going towards ignition. 3 thin wires, yellow, black &black w/yellow stripe.
Door locks may require up to 4 relays. |
thanks ill look for them
There is a module that connects directly to the data bus so you dont have it rigged w/ a key stuck under the dash... Door locks shouldn't require any relays, just tap the unlock from one of the rear doors. If i remember correctly there was an issue w/ tapping the drivers door think it only unlocked itself, not all doors.
Can't help you as MURRAY'S installed mine but HEY AND WELCOME Fellow Pegger!!!!:)
cool another pegger
is there another way of telling which wires are for the passlock bypass
I used to install these for circuit city back in high school. I would honestly recommend not to use the Remote Start feature. They almost cause problems several years down the road. Then it gets expensive to make repairs etc.... I was a MECPInstaller and that is my professional opinion.
I agree that the remote feature will cause problems in the long run
| All times are GMT -5. The time now is 05:19 AM. |
