remote start anyone?
I have a 2007 H3 Adventure. I have read all the threads on this site regarding remote start. I have yet to find one refering to an install on a 2007 model. Has anyone installed, if so what's a good brand and were there difficulties. I tried last summer to haveone installed and the installer burned up my ECM. Thanks.
I believeif you purchase a good alarm system, you might as well add the remote starter, it's a good add-on. I have the Clifford Matrix 50.5x with a few additional modules. I'm very happy with it.
I have a Compustar Pro P2W9000FMR!!! It's AWESOME and COOL!!
Remote start WITH Paging Alarm!!
[align=center][/align][/align]
Up to 3000* feet of Range
This new CompuStar Pro 2W9000FMR remote has a built in clock, in-vehicle temperature readout, and battery voltage sensing. This system operates at a higher frequency to allow for greater range and battery life. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications and we've taken this technology to the next level with the 2W9000FMR Pro.
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
View the manual for the P2W900FMR
View the manual for the P1W900FMR
[/align]
Pro Remote Features
- Two-way paging remote
- New multi-color LCD (liquid crystal display)
- CompuGlow backlight
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking Meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with remote)
- Turbo Timer (extendable with remote)
- Secure Auxiliary Mode
- Shock sensor on/off through remote
- Passive mode on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
[/align]Pro Starter Features | P2W9000FM-S
Pro Alarm/Start Features | P2W9000FM-AS
[/align]
- Includes anti-grind and optional starter-kill relay
- Factory Style Alarm, monitors doors and trunk
- Time start set on remote by user
- Optional external Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Secure valet switch
- 2-auxillary outputs, expandable to 7 with Channel Expander
- 2-programmable inputs
- Selectable trunk release output
- Programmable horn honk output
- Horn trigger output
- Diesel timer built-in
- Manual transmission compatible
[/align]
- Includes anti-grind and starter-kill relay
- Battery backup capable
- External Siren (six-tone)
- Includes dual stage shock sensor
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
[/align]
Pro Remote Features
- Button lock
- Timer Start Mode
[/align]
[/align]
- Anti-Jacking mode
we have it on our 06,had it installed and then i did my own on my silverado.just dont buy some cheap setup off ebay.the hummer has an autopage which is awesome,and my truck has a crimestopper which is second to none the best IMO.
I had the dealership install one for me. It is an Audiovox and does what I need it to do. I get good range, and have a warm seat to sit on when I get in (I leave my heated seat switch in the on position when I turn off the vehicle so it kicks on with the remote start). I wanted to follow HummBob's lead and get the same type, but it just didn't work out.
Had it in the 06 and we have it in the 08, both factory installed. They work great and I am going to put one on my Tact, just have to decide which is higher priority: Tires, Cat-back, starter, shocks. Leaning towards tires first then starter, shocks, cat-back. BLAH, BLAH, BLAH
Anyway, I love the remote starter. Especially when it is 16 degrees outside!
Does anybody have the factory setup? I thoughtI have seen that as an option.
